3D Transparency for Glass
Question, how do I make glass non transparent in a Parallel Projection Setting window while in 3d? Using AC23.
Thanks
Turn off Transparency in the 3D Styles Dialog?
Yes, 3D Styles is the solution. This was a different name and place than the last version.
Thanks
