2011-03-16
05:13 PM
2023-05-24
11:51 AM
Rubia Torres
2011-03-22 11:37 PM
2011-03-23 01:12 AM
2011-03-23 02:37 AM
P.S. It would be really Great If Graphisoft includes those options for Complex Profiles
2011-03-23 08:55 AM
BODY -1 MODEL WIRE BLOCK a,b,zzyzx/2 BODY -1 IF GLOB_CONTEXT>2 THEN addz zzyzx/2 MODEL SOLID BLOCK MAX(0.0001,A*100/GLOB_SCALE),b,zzyzx/2 ENDIF BODY -1Placed 15 instances in 50m distance in between didn't show any changes in the scale dependent length of the upper block of the object.
2011-03-23 12:49 PM
F. wrote:Frank:
As far as I have determined there is no helpful usage ofg GLOB_SCALE in 3D window, because it returns always the scale of the curerently visible floor plan window.
2011-03-23 04:55 PM
2011-03-23 10:03 PM
2011-03-23 10:04 PM
2011-03-23 10:26 PM
! 3D Scale : 2D Script Text2 0, 0, Glob_Scale
! 3D Scale : 3D Script Text 1", 0, Glob_ScaleThen create two Views for the 3D Window, each with a different scale as shown in my earlier image. When changing views, the text will change to reflect the scale.
