3D stretchable hotspots
dhaval7shah
1) How to script editable 3d stretchy hotspots ?
2) I want a 3D pole element with Ellipse at base and circle at top, how should we script it?
Dhaval Shah
Upto AC 22
iMacs and MacBookPros: Mac OS X (10.6 to 10.12, Intel core 2 Quad to i5, i7, 8 GB to 16GB)
Win 10, AMD Opteron 6-Core x 2, 16GB, FirePro W4100 2GB
& ThinkPad E550
& i7, 8GB
Erich
First you should look at the GDL Reference Guide available as a pdf from your Help menu.
3D hotspots are written with three lines of code as follows:
	HOTSPOT 0, 0, 0,   unid, var, 1+128 : unid=unid+1 !base
	HOTSPOT 0, 0, var, unid, var,     2 : unid=unid+1 !move
	HOTSPOT 0, 0, -1,  unid, var,     3 : unid=unid+1 !reference
This bit of code will create a hotspot to control the parameter var stretchable in the Z direction. This parameter must also be present in your parameter table. Also note that each hotspot has a unique id number. I find it good practice to define unid=1 at the begining of my scripts and then the the notation
: unid = unid+1
after each hotspot definition to avoid getting duplicate hotspot ids.
As for the sphere/pole/ellipse there are many ways. Look at the SPHERE, ELLIPS and CYLIND commands for a start.
HTH
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
David Maudlin
Dhaval:
You should look at the RULED command, page 92 of the GDL Reference Guide, this creates a form with different polygons on each end.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
dhaval7shah
Thanks a lot Erich and David.
Dhaval Shah
Upto AC 22
& ThinkPad E550
& i7, 8GB
