2012-07-05 03:09 AM
2013-03-06 08:49 AM
2013-03-06 03:00 PM
sarahric wrote:It's a tree, I don't expect precise dimensions (now if it was that way for Columns, different story). You can always decrease the size to get a smaller diameter.
How did you go with the actual size of the tree. Is it beyond the size given?
sarahric wrote:Another option is to place the tree/bush on a layer that is visible for the exterior rendering, but hidden for interior views, if you are not showing both at the same time (like with BIMx).
I have a project where I wanted a low small tree (almost a bush, but the bush object is not appropriate) in my 3d rendering right next to the house, but I couldn't make it look right without leaves floating of and inside the house!
2013-03-07 12:10 AM
