3d and 2d objects of pepole and childrens for rendering
hello, i am rendering frome archicad and need 3d and 2d objects of pepole and childrens for rendering, were can i get new 3d objects?
6 Replies 6
sorry for another post, but here is another one
http://archicado.free.fr/
Thank you, Paulo
i downloaded files frome the links you gave me.
i have a *.lib format file
and frome the seconde linki each zip file cntains 3 files in format *.prw *.bb and *.tga
what should i do with the files?
You dl the files to use in the artlantis program. 🙂
you have to choose the archicad files.
i dont use artlantis i am rendering with maxwell. becuse of that i need to insert the o bjects into the archicad 3d model
ok,
did you see the tab for AC objects in the top of the page?
the .lib extension is used for AC, just put in the library folder and load it
in AC.
in the archicado site, just select the archicad object tab, and choose your objects. (.zip) you will have to decompress after.
hope that helps.
