Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. License Manager Tool update is required on Windows. Learn more…
3d text
Hmm.. i havent 3d text in library.. where i can get it ?
25 REPLIES 25
David Maudlin
baklazh:
In the US version it is an object named "Text 3D 10" and can be found at: Object Library 10 > 01 General 10 > Pictures and Texts 10 folder. This object has also been in earlier libraries.
HTH
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Djordje
Ace
If we knew which Archicad you use, onwhich platform, it would be much easier to answer ...
And, where is your home that you are located at?
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
i cant find it 😕
Djordje
Ace
baklazh wrote:
i cant find it 😕
Did you open each folder and subfolder, one by one?
Djordje
HP Omen
i found it
but when i extrude that text in wall .. that wall dont keep that extruding
Don't understand it!?
Anyway, what do you want to do?
Dwight
Proof that it works.
Dwight Atkinson
yess your are PRO
but i dont know how to do it!
