Steve Jepson
.3ds objects
how do I get .3ds objects into ArciCAD?
I have ADT 3.3 and the GDL Objects Editor add-on for it
and 3ds max 7 demo. I am also having trouble getting
3D .dwg files to open in ArchiCAD now. I used to do it. Is this still an option?
12 Replies 12
I hear about problems to import .3ds files in AC9. In AC8.1 the "3DS Konverter" works fine. It is in German, and you can find it here http://www.gshelp.de/CDownloads/Downloads81import.html .
Hope that helps.
Steve Jepson
Merci. Cela fonctionne très bien. I avec eux ont eu un anglais version. Je ne sais pas l'allemand très bien.
Steve Jepson
C'est.l'objet 3ds j'étais ensuite. Je l'ai trouvé au HTTP ://www.e-intérieurs.net/index.php
Ils ont beaucoup d'objets 3D libres.
Je l'ai fait avec "Lightworks"
Hello Steve
Great job with Lightworks . Rendering is not the part of the architect job where i am really good.
Thanks for the french reply —your french is better than my english—, it is really a pleasure for me. .
I know your 3DS links e-interieurs.net.
You can find this one and other in this area http://annuaire.fc-cadlink.com/ in french and more here http://www.cgarchitect.com/links/default.asp in english.
I put some of them here http://archicad-talk.graphisoft.com/viewtopic.php?t=2434
stefan
ArchiCAD 9 includes the 3ds-import plugin by default.
You can open a 3ds-object as a library element. Try it. It worked for me (although I don't have a need to load 3ds-files into ArchiCAD. I usually do the reverse).
Archicad-user since 1998
my Archicad Book
Steve Jepson
Thanks Stefan, I found it. It works great.
Hi I am new in ArchiCAD, reading this post then I realize I didn't have this 3ds import tools in my ArchiCAD 9.0, please help me to get this addon. Thank you!
Steve Jepson
its in the add-ons folder. Import-Export. It should load automatically.
click Tools, Add-On Manager, Search for more Add-ons, uncheck the Hide Loaded Add-ons box so you can see what is in the folder. 3D Studio Out should be there.
If not you can download it. I don't remember where from, but I have downloaded it before. Some one else can probably help you with that.
Thank you Steve, yes the 3DStudio Out.apx loaded well in AC9, but what I need is addon for importing, like 3ds_in.apx in AC8.1. Because I still don't have that menu in the section "Extra" on tool bar like yours even 3DStudio Out appear in my addon manager window........
Please, if you have, could you upload for me? Thanks before....
