9.0 parameters don`t show up in 8.1
my objects made in AC9.0 are ok till I open them in 8.1,
all the parameters just dissapear...
this happened to anyone or is just me?
3 Replies 3
Frank Beister
How can you open 9.0 objects in 8.1? PLN and GSM is not downward compatible, isn't it?
Well, one can save a .pln in an earlier format,
I know they don`t work backwards.
but I had no idea it`s the same with .gsm files.
So, if I need the library objects in both 9.0 and 8.1 I have to do them in 8.1??
Frank Beister
I think so, yes. Better do it in 7.0. Then you can use it in start edition too. 😉
