Hello, Frank and Laszlo,
I thank you both for posting back.
Laszlo, you are saying that the status code f1 controls whether
the cut surfaces of the body being cut will have the material and pen
defined for the wrest of the cut body or the material and pen
of the cutting body, similar to the choice for SEO.
I will have to experiment because I have
never wanted the the cut surface to be different from the
the wrest of the cut object.
Frank, have you seen the strange effect I described when
f2 is set to zero ? This is seen in the Section/Elevation window
when the object is cut by a section line. See image below.
I will have to see what you mean about the consequence
of alternate f2 settings on the PROJECT2{3} command.
Do the two of you agree that a "normal" polygon is an uncut polygon
and therefor a non-normal polygon is a cut polygon ?
Thank you,
Peter Devlin
