A "Smart" roof label
I've searched this forum and can't find anything.
I want to make/get a label object that can be used in the following manner:
Click on a roof then click on the desired location for the label. The label needs to display the rise and run of the 'clicked on' roof.
Is this possible? and How?
82 Replies 82
Richard wrote:
Dan,
This looks like a great tool, but it isn't picking up the slope for me. Any idea what might be wrong? (It inserts as a 0:12 slope) Roofs are unlocked and displayed.
Thanks, make sure you are placing it as a roof accesory...How are you placing it?
Dan K
Rakela wrote:
thanku dan,
im looking x gas to run my generator, but still i wont miss
this goody.
i envy who doesnt have hurricane/tornados, and quakes
You're welcome...hope it works well for you!
Dan K
Dan K
Well, that works a lot better! (I was placing it like a standard object previously.)
Thanks!
Richard
AC26 (since AC6.0), Win10
Dan wrote:
For anyone interested I'm posting an updated/enhanced version of this roof accessory. Basically it fixes an arrow direcion problem thanks to a suggestion by Peter Devlin. It also allows you to display the slope in feet and inches.
A more informative screenshot will follow this post
Dan K
Can someone translate this acessory to show the option for metrics?
Dan, which part of the GDL script should I change?
rslope=ABS((tan(AC_pitch))*12)---->Why 12?
Jaime Neto
PowerBook G4, Archicad 9.0
Jaime Neto
Jaime,
The accesory is written the way US users indicate roof slopes. Basically the slope is always based on how much rise in inches occurs in 12 inch run...or how much rise in feet occur in a 12 foot run.
I can add some parameters to display the slope in degrees or even percent. Just let me know how you, preferably, indicate your roof slopes in metric?
As far as "Why 12?" goes, its basic trig calculating rise over 12 units of run...It's really just an imperial units kinda' thing.
Nuge
Dan,
This is a great tool well done, it could be even better if we could show the pitch as a degree.
Just my 20 cents worth!!
Keep up the good work
Cheers Nuge
AC27 i9 14900KF / 128G ram / GTX 5090 / D5 Render
Nuge wrote:
Dan,
This is a great tool well done, it could be even better if we could show the pitch as a degree...
Thanks Nuge,
Based on yours and Jaimes' comments, I've updated the part to include options for displaying slopes in degrees or percent. Hope it works better for you now...The updated part will be attached in the following post.
P.S. What is the metric standard for indicating roof slopes on roof plans? ...degrees?
Thanks,
Dan K
OK,
here's the latest version
Now also includes options for displaying slopes in degrees or percent.
Dan K
Nuge
Thanks Dan look Great,
Not sure what the "metric standard" is but here in New Zealand everything is noted and discussed in degrees
Hope this helps
Cheers Nuge
Hope this helps
Cheers Nuge
Nuge,
In the US we typically indicate slopes pointing down the slope...Is this the way you do it?
I know it sounds silly, but just want to verify because your standards for wdw/door hinges are opposite of ours.
Dan K
