A "Smart" roof label
I've searched this forum and can't find anything.
I want to make/get a label object that can be used in the following manner:
Click on a roof then click on the desired location for the label. The label needs to display the rise and run of the 'clicked on' roof.
Is this possible? and How?
82 Replies 82
Aussie John
Joseph, I think it is working here
Cheers John
[/size]
Thanks for checking,
I downloaded it again and put it in my loaded Library folder and still it does not show up in Label Settings. Should I go through any other steps?
Thanks,
Joseph
Sorry,
I had forgotten that it is an Object Library part!
But now that I place it as an object on a roof with the Roof Gravity on it gives me 0:12 slope. For some reason it does not pick the slope. Any thoughts?
Thanks,
Joseph
Joseph,
It's a roof accessory.
Select the roof, go to extras/roof accessories, select it,
and it appears in the plan
Peter Devlin
Joseph,
It occurs to me you may have the library part in the wrong folder.
It should be in object library/add-on library/accessories library/
roof accessories.
Peter Devlin
Aussie John
Thanks,
Joseph
As Peter says its not an object nor is it a label but a roof accessory. It doesnt need to be in a specific folder.
Cheers John
[/size]
John,
You say that "it does not have to be in a specific folder."
I just did an experiment because your statement made me think
that I had acquired an erroneous AC superstition.
I took the "RoofSlope_accessory" and put it in the Markers folder.
Then I selected the roof and went to roof accessories and
the accessory was not there but it was in the object tool browser
inside the markers folder and it behaved as Joseph has described.
I put the accessory back into roof accessories and re-loaded libraries
and it worked again.
I am puzzled. How can you get it to function or show up as a roof
accessory if it is in another folder ?
Thank you,
Peter Devlin
Peter wrote:
John,
Thank you,
Peter Devlin
If I may chime in here.
If the object sub-type is set as "Roof (Accessory)" then it will appear as both an object you can place as normal with the object tool and also as an object when using the EXTRAS > ACCESSORIES... menu.
Using EXTRAS > ACCESSORIES.... you should see the entire library but only the hierachy of folders that contain "Accessory" sub-types.
These can be placed anywhere in the library - you just need to know where to go looking for them.
Aussie John
Peter wrote:
John,
Thank you,
Peter Devlin
Peter I can put the accessory any where and "Archicad" finds it when I open up the roof accessory
Cheers John
[/size]
Thanks, you are all great for sharing so much know how. This is why AC is so great!
Thanks,
Joseph
