2005-10-13 09:36 PM
2006-03-02 12:59 AM
2006-03-02 01:25 AM
Aussie wrote:Thanks for checking,
Joseph, I think it is working here
2006-03-02 02:10 AM
2006-03-02 03:19 AM
2006-03-02 03:29 AM
2006-03-02 03:37 AM
Joseph wrote:As Peter says its not an object nor is it a label but a roof accessory. It doesnt need to be in a specific folder.Aussie wrote:Thanks for checking,
I downloaded it again and put it in my loaded Library folder and still it does not show up in Label Settings. Should I go through any other steps?
Thanks,
Joseph
2006-03-02 04:06 AM
2006-03-02 08:44 AM
Peter wrote:If I may chime in here.
John,
You say that "it does not have to be in a specific folder."
I just did an experiment because your statement made me think
that I had acquired an erroneous AC superstition.
I took the "RoofSlope_accessory" and put it in the Markers folder.
Then I selected the roof and went to roof accessories and
the accessory was not there but it was in the object tool browser
inside the markers folder and it behaved as Joseph has described.
I put the accessory back into roof accessories and re-loaded libraries
and it worked again.
I am puzzled. How can you get it to function or show up as a roof
accessory if it is in another folder ?
Thank you,
Peter Devlin
2006-03-02 11:26 AM
Peter wrote:Peter I can put the accessory any where and "Archicad" finds it when I open up the roof accessory
John,
Thank you,
Peter Devlin
2006-03-02 08:14 PM
If the object sub-type is set as "Roof (Accessory)" then it will appear as both an object you can place as normal with the object tool and also as an object when using the EXTRAS > ACCESSORIES... menu.
Using EXTRAS > ACCESSORIES.... you should see the entire library but only the hierachy of folders that contain "Accessory" sub-types.
These can be placed anywhere in the library - you just need to know where to go looking for them.
