AC 17 3D Document - Door Opening
Llian
How/where do I set the door opening to be the same as in the view map?
The 3D view is showing it closed....I hope I am not spending the time to drawing 2D opening in dashed line....
Lilian Seow
LEED AP | cSBA | CAPM | PMP
Interior-Architecture and BIM Management
AC20 USA | 27- macOS 10.14.6| 4 GHz Intel Core i7| 32 GB RAM | Archicad-user since 1994!
4 REPLIES 4
Stress Co_
Opening Lines... 3D projections.
Note the Model View Override button.
See attached:
Marc Corney, Architect
Red Canoe Architecture, P. A.
Llian
Thanks....where can I find this setting...in the Door object or Model View Option ?
Lilian Seow
Llian
here's the door object setting but not seeing what you have..
Lilian Seow
Llian
OK, I found it.....
Lilian Seow
