2021-07-12
		10:14 PM
		2023-05-24
		10:18 AM
			Rubia Torres
2021-07-15 06:12 PM
2021-07-15 10:20 PM
2021-07-15 11:00 PM
2021-07-16 01:18 AM
2021-07-16 03:33 AM
lparke wrote:
2) at a two segment base cabinet, when I set the lower segment to a double hung door with drawers above I can't figure how to show two drawers side by side above the door panels. It only appears we can have one large drawer.
2021-07-23 02:16 PM
lparke wrote:If I understand it correctly, what you want is to show dash lines for opening door swing? In the screenshot below you can find this option under
I'm reworking our template favorites for cabinets to incorporate new features of AC25. Perhaps I haven't found it but can you:
1) show dashed lines indicated door swings and shelving behind the doors in 2d elevations
lparke wrote:Unfortunately, that is correct. In the new object, somehow the drawer cannot be split into multiple segments. Unfortunately, the best option I could think of is modeling 2 separate cabinets, or set the upper cabinet to have
RandyC wrote:Hi Randy, I'm not sure if this is the option you are looking for:
lparke :
Thank you for looking for me -- I found that command but it is the cabinet lines that I need to hide
the countertop lines disappear properly but the cabinets show through , If I change line type or line color to white they still do not show properly / -- looking for a cleaner presentation until I have to sit and design the kitchen --
Randy
Minh Nguyen
Technical Support Engineer
GRAPHISOFT
2021-07-24 12:27 AM
2021-07-24 12:31 AM
2021-07-26 03:39 PM
Minh Nguyen
GRAPHISOFT
