MO_RHTX
AC26 US Electrical Symbols
I cannot seem to find the US electrical symbols. I am looking for the object file that represent outlets like the screenshot attached.
Does anyone know where I can download this US library for these symbols?
us outlet symbolus outlet symbol
AC26/windows 11 pro
1 Solution
Eduardo Rolon
It is not in your library
That object is part of the US Library, looks like you have installed AC International Version,
To get access to the US Library you will need to download and install the US Version of Archicad and then you can copy that library.
You can have both versions of AC installed without issue.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Go to post
4 Replies 4
Eduardo Rolon
Tha is the same one
You need to edit the settings
Or are you using another version of AC that is not the US one?
If that is the case just download the US version, install it and copy the Library.
AC29 US/INT -> AC08
MO_RHTX
Hi Eduardo,
I am looking for the object shown in the screenshot. I am unable to find that in my ArchiCAD library. What I have is the one shown here and it does not give me options to edit. Is there a library I am missing?
Eduardo Rolon
AC29 US/INT -> AC08
Botonis
Mentor
If you support this maybe someday everything will be possible:
https://community.graphisoft.com/t5/Wishlist/Intergrate-Electrical-Design-Capabilities-for-Architect...
