Lingwisyer
Guru
AC30: Expanded Label Shapes
So one of the New Architectural Features in AC30 is Expanded Label Shapes. I have to wonder why they did not just pull all of the available shapes from the Label Macro.
All shapes available in the Label Macro
New shapes available in the default label.
Ling.
1 Solution
Karel Landa
I had the same question in BETA program.
Answer was that based on analytical data, the rest of shapes were not that much used...
From Archicad 17
MacBook Pro M1 Max
Go to post
5 Replies 5
Karel Landa
From Archicad 17
MacBook Pro M1 Max
Lingwisyer
Guru
Though that answer also implies that they were sometimes used, so why limit it when it is already there? Some millisecond performance penalty when opening the drop down?
Funfun Yan
The "Answer " seems like replyed by AI.
James B
As @Karel Landa  said. Thanks for responding.
We focused on the most requested shapes, and based on usage analysis. Putting our effort in implementing shapes you need and use was preferred, regardless of if they are in or not in GDL Labels (and in that case, we can reconsider the GDL shapes...).
James Badcock
Keny90
We need to save something for the AC31, too. There was such a huge batch of new developments this time that it just wouldn't all fit in...
