2005-10-19
07:25 AM
2023-05-24
12:48 PM
Rubia Torres
2005-10-19 04:28 PM
vincon2 wrote:It appears that you may not be using the most current SE library. All the current parts have an SE aappended to the part name. In the latest library there exists the following window:
...I believe I have found a glitch in one of the new library parts.
The W1 Casement AwnU window under Wood Plastic Windows 9 of the new special edition AC9 library does not have the option for brick mortar like the other windows do for masonry arch. Also, when I choose the masonry arch and set the brick heights, etc, the brick header doesnt show up on the elevation section...
2005-10-27 09:06 AM
2005-10-27 07:34 PM
