Glitch w/ updated SE library
I found a glitch with the garage doors from the updated SE library. The custom door panel settings do not show my door panel object. I tested the object in all three SE garage doors, and all failed to show the new door panel, but rather some other object. I checked with a couple of the other door type and they showed my door panel just fine, as did the garage doors from the standard AC library. I'm guessing there is just a line or two of GDL I could paste into the SE garage doors to make them work, anyone know anything about this? I've attached the door panel I am using.
The door material settings don't seem to have any effect either
0 Replies 0
