‎2006-03-17
05:40 PM
‎2023-05-24
12:47 PM
Rubia Torres
‎2006-03-18 06:39 AM
‎2006-03-18 04:06 PM
‎2006-03-18 05:26 PM
Peter wrote:Library parts that you have modified in this way should be saved in an alternate library and renamed to reflect that they use your standard defaults. This way you don't run the risk of losing the work when GS updates the SE library.
josh,
Open the object via file/GDL object/open object.
You will see the parameter list. Change the values of
the parameters you want and save.
The object now has new default values.
Peter Devlin
