AC9 SE Lib - Door and Window defaults
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2006-03-17
05:40 PM
ā2023-05-24
12:47 PM
Rubia Torres
ā2006-03-17
05:40 PM
Is there anyway I can set those settings to default, so I do not have to go in and change the settings everytime I start placing doors/ windows.?
(other than the copy attributes eye dropper technique?)
Does this make sense, or do I need less coffee and more sleep?
Thanks
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-03-18 06:39 AM
ā2006-03-18
06:39 AM
I am not yet an advocate for the SE Library, but for any Object this is were you save the Modified Object as a Favorite.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-03-18 04:06 PM
ā2006-03-18
04:06 PM
josh,
Open the object via file/GDL object/open object.
You will see the parameter list. Change the values of
the parameters you want and save.
The object now has new default values.
Peter Devlin
Peter Devlin
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2006-03-18 05:26 PM
ā2006-03-18
05:26 PM
Peter wrote:Library parts that you have modified in this way should be saved in an alternate library and renamed to reflect that they use your standard defaults. This way you don't run the risk of losing the work when GS updates the SE library.
josh,
Peter Devlin
It is a pain in the neck either way though (resetting the parameters at each update or maintaining the extra revised parts). I usually prefer to create modules of preset parts to import into project files or (less often) to use the Favorites.
Remember of course to syringe (command/ctrl + option/alt) click in the settings dialog when switching from a correctly set door to a different one.
