2005-12-14
09:12 PM
2023-05-24
12:47 PM
Rubia Torres
2005-12-16 12:02 AM
2005-12-16 12:17 AM
2005-12-16 12:39 AM
Jay wrote:
Sorry to say I am still a bit confused about whether the wall Type was anything to do with whether I am using a "basic" wall or a Composite wall.
2005-12-16 01:32 AM
Erika wrote:So a Solid Wall Type "shows" the sills and casings differently than a stud wall and stud wall with siding wall. Your previous image files seemed to "show" thes items for the Solid wall.
You can use a basic/single-fill wall type for bothstud walland stud wall with siding. This is telling the window/door that it is in an interior or exterior wall and shows sills, casings etc. accordingly.
HTH
2005-12-16 06:26 PM
2005-12-16 07:07 PM
2005-12-16 07:25 PM
Jay wrote:
but I can not seem to set the parameters on the SE library and achieve a window that does not produce Warnings and errors.
2005-12-16 07:31 PM
Jay wrote:Jay,
We vary rarely use Brick up here in the Mountains and most (85& or so) of our siding applications actually run underneath the trim. In otherwords the window trim is nailed on over the Siding. Only for a steeply Beveled siding is the siding cut to butt with the window trim like the "Stud wall with Siding" wall type displays.
2005-12-16 08:03 PM
Erika wrote:To clarify: you must report bugs to your local/regional tech support so that the issue is entered into the bug database (the master "to do" list). (For the SE library, that would be GSUS support, since this is a US library.)
As Karl said, keep posting the problems you come across them so the programmers will know what to correct.
