ā2022-09-24
11:11 AM
ā2023-05-24
09:42 AM
Rubia Torres
Sometimes I need to show just the walls, without the windows or doors. Currently there is no way to do this. If I hide windows/doors that also hides the host wall. I'd like to be able to hide windows/doors without hiding their host walls.
This wish is particularly important if you work a lot, like I do, with prefabricated and panellised walls. I have a workaround for this but I don't like it as it imposes extra work and as with all workarounds I have to be careful not to break it.
Solved! Go to Solution.
ā2022-09-24 04:07 PM
Hi @Professor Pickle, Iām sure You can hide W&D in floor plan via Document > Model View > Model View Options > Construction Element Options then from Door and Window drop down list choose Hide on Floor Plan.
In 3D View you can hide them via View > Elements in 3D View > Filter and Cut Elements in 3D then from ( Element Types to Show in 3D ) uncheck Door & Window, I hope it helps.
ā2022-09-24 11:55 AM
This is already possible using the Model View Options filter in Archicad.
ā2022-09-25 06:08 AM
This is exactly what I wanted. I always forget about that 3D filter. Thanks!
