Adding a RADIUS to a steel beam in the object libray!
Hi everyone,
I am using ArchiCAD 8.1 and need help on adding a radius on a steel beam so that i can use it as a rafter in a curved roof. I would greatly appreciate it if somebody could help me out by either telling me how to do it or just doing it for me.
thanks.
15 REPLIES 15
Djordje
Metin wrote:
i know about the "web beam curved" but i want to be able to curve the beam that i have posted. as it allows you to select the section type and weight easily.
Using the TrussMaker you can specify your sections.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Thanks Djordje i will give that a try.
Aussie wrote:
actually on closer examination the tube command cant follow a curve path
Just for the sake of discussion: if it is a circular path then you can probably use the sine and cosine method for setting y and x values for each point that DNC makes so much use of in his Cookbook. I think. Sort of. If on the other hand it is a parabolic or hyperbolic or catenary or other path, then err of course you know the formula.
fuzzytnth3
Is it an I beam you are after? I made a couple of curved beams a while back I could let you have.
AC versions 3.41 to 25 (UKI Full 5005).
Using AC25 5005 UKI FULL
Mac OSX 10.15.7 (19G2021) Mac Pro-2013 32gbRam AMD FirePro D500 3072 MB graphics
That is exactly what i am looking for. Does it allow you to select the type of beam eg. 250 UB 27. if not its still ok. if you dont mind can i get a copy of it?
Thanks for your help.
fuzzytnth3
I've uploaded an Archive file here... http://homepage.mac.com/fuzzytnth3/TLOTT/
You have to type in the overall size of the beam and flange and web sizes less laborious to script that way
Enjoy
