‎2004-08-18 10:41 AM
‎2004-08-19 08:15 PM
Metin wrote:Using the TrussMaker you can specify your sections.
i know about the "web beam curved" but i want to be able to curve the beam that i have posted. as it allows you to select the section type and weight easily.
‎2004-08-20 03:11 AM
‎2004-08-20 08:32 AM
Aussie wrote:Just for the sake of discussion: if it is a circular path then you can probably use the sine and cosine method for setting y and x values for each point that DNC makes so much use of in his Cookbook. I think. Sort of. If on the other hand it is a parabolic or hyperbolic or catenary or other path, then err of course you know the formula.
actually on closer examination the tube command cant follow a curve path
‎2004-08-25 06:13 PM
‎2004-08-26 01:39 AM
‎2004-08-26 07:00 PM
