2020-02-11 05:24 PM
poly2_b{5} 13, 3, 0, 3, 19, 19,
0, 0, 1, 0, 0, 1, 0,
posx1, posy1, 1,
mposx1, mposy1, 900,
0, -180, 4001,
posx2, posy2, 1,
mposx2, mposy2, 900,
0, -180, 4001,
posx3, posy3, 1,
mposx3, mposy3, 900,
0, -180, 4001,
posx4, posy4, 1,
mposx4, mposy4, 900,
0, -180, 4001,
posx1, posy1, 1
FYI Master Scriptmposx1 = ((posx1+posx2)/2) mposx2 = ((posx2+posx3)/2) mposx3 = ((posx3+posx4)/2) mposx4 = ((posx4+posx1)/2) parameters mposx1=mposx1, mposx2=mposx2, mposx3=mposx3, mposx4=mposx4 mposy1 = ((posy1+posy2)/2) mposy2 = ((posy2+posy3)/2) mposy3 = ((posy3+posy4)/2) mposy4 = ((posy4+posy1)/2) parameters mposy1=mposy1, mposy2=mposy2, mposy3=mposy3, mposy4=mposy4And the pos values are as follows -
2020-02-14 01:15 PM
2020-02-16 12:37 PM
2020-02-23 08:01 PM
JGoode wrote:Something like this?
The method I want to use to be able to adjust the curve is have a centre point half way between the 2 points and then set the distance from the centre point to the arc – Is this possible to do in a fill and if so, how can I do it?
Braza wrote:What Braza states is accurate; but maaaaannn.... I remember doing the trig calculations and it sent me back to school.
If you want to control the arch using a length hotspot, you will have to tie the arc angle and center point with this length.
You just have to do the trigonometry
2020-02-24 02:46 AM
