2019-08-23 02:20 PM
HSID=1 hotspot2 0, 0,HSID, widthx, 1+128 !base HSID = HSID+1 hotspot2 -1, 0, HSID, widthx, 3 !reference HSID = HSID+1 hotspot2 widthx, 0, HSID, widthx, 2 !moveableThanks
2019-08-26 03:49 AM
GDL wrote:
Use the REQUEST ("TEXTBLOCK_INFO", ...) function to obtain information on the calculated width and height of a textblock.
TEXTBLOCK "papersize1" 0, 7, 0, 1, 1, 0, Label_Length
dummy = REQUEST ("TEXTBLOCK_INFO", "papersize1", width)
text_offset = width / (1000 / GLOB_SCALE)
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | i9 11900K | 32GB | GTX2080TI |
2019-08-27 10:47 AM
2019-08-27 11:01 AM
HOTSPOT2 0.0, 0.0
DEFINE STYLE "AC_STYLE_1" "Arial",text_hgt,1,0
IF symb_mirrored = 1 THEN
MUL2 -1, 1
ADD2 -box_wid,0
ENDIF
tab_1 = 0
left_indent = 1
stringval_1 = "Add your note here. You can type what ever you like"
PEN 1
IF symb_mirrored = 0 THEN
justification = 1
ELSE
justification = 3
ENDIF
!Define a paragraph
paragraph "note_1" justification,
0, left_indent, 0,
1,
tab_1
SET STYLE "AC_STYLE_1"
"\t" + stringval_1
endParagraph
!Include the paragraph in a text block
!!TEXTBLOCK name width, anchor, angle, width_factor, charspace_factor, fixed_height,
!!'string_expr1' [, 'string_expr2', ...]
textBlock "text_block_1" (box_wid*1000/A_),
7, 0,
1, 1, 1,
"note_1"
rrr = REQUEST("Textblock_Info", "text_block_1", textblockwidth, textblockheight)
box_hgt = box_hgt + textblockheight*(A_/1000)
!Place the block using the richtext2 command
richText2 0, 0, "text_block_1"
!stretchy hotspot - note width
hsid=hsid+1 !base
HOTSPOT2 0,0,hsid,box_wid,1+128
hsid=hsid+1 !moving
HOTSPOT2 box_wid,0,hsid,box_wid,2
hsid=hsid+1 !reference
HOTSPOT2 -0.0001,0,hsid,box_wid,3
hsid=hsid+1 !base
HOTSPOT2 0,box_hgt,hsid,box_wid,1+128
hsid=hsid+1 !moving
HOTSPOT2 box_wid,box_hgt,hsid,box_wid,2
HOTSPOT2 -0.0001,box_hgt,hsid,box_wid,3
2019-08-27 11:47 AM
2019-08-28 03:13 AM
JGoode wrote:
This definitely works and I had tried it but is there any way to make the text maintain the same shape when scale is changed?
Thanks
DEFINE STYLE "AC_STYLE_1" "Arial", text_hgt * GLOB_SCALE / 1000, 1, 0
2019-08-28 04:33 AM
JGoode wrote:As I understand it, you want the width of the text block to change depending on the scale.
Thanks
box_wid = box_wid*A_/100 PARAMETERS box_wid = box_widBut this won't work as GLOB_SCALE no longer works in the parameter or master script.
2019-08-28 05:21 AM
2019-08-28 05:54 AM
2019-08-28 05:59 AM
