2024-01-20 10:35 AM
I use Steel Object [Lipped C section beam] but I can't use 2d hotspot to adjust its length because when I do that The elevation of beam will move. Anyone face this problem ?
2024-01-20 12:23 PM - edited 2024-01-20 12:24 PM
Are you facing the same problem if you adjust length in 3D view? Or it’s related to 2D floor plan only?
2024-01-20 01:12 PM
Not happen in 3d view. It happens only in 2D view but I don’t know why.
2024-01-20 05:20 PM
I can use steel beams normally as they’re elements not objects so try to use beam tool rather than the object one.
2024-01-22 08:03 AM
because in the 2D view you are only changing the length not the slope.
2024-01-22 09:41 AM
This all comes down to how the object was scripted. The coder has not looped adjustment of the bottom nodes in plan to a change in the objects elevation...
| AC22-29 AUS 3200 | Help Those Help You - Add a Signature |
| Self-taught, bend it till it breaks | Creating a Thread |
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
