Steel Object Bug when use 2D hotspot ot adjust its length
Akpocky
I use Steel Object  [Lipped C section beam] but I can't use 2d hotspot to adjust its length because when I do that The elevation of beam will move. Anyone face this problem ?
CPU: INTEL I3-12100 F 3.30GHz
VGA: RTX 3050
RAM:16GB
WINDOW 11 22H2 OS BUILD 22621.1848
Archicad 27 Build 4030
5 REPLIES 5
Are you facing the same problem if you adjust length in 3D view? Or it’s related to 2D floor plan only?
AC 28 INT 3110/WIN 11
Not happen in 3d view. It happens only in 2D view but I don’t know why.
VGA: RTX 3050
RAM:16GB
I can use steel beams normally as they’re elements not objects so try to use beam tool rather than the object one.
because in the 2D view you are only changing the length not the slope.
Archicad 4.1 to 28 Tech Preview. Apple Silicon
you can't build a line
Mac Studio
iPad Pro
iPhone
Lingwisyer
Guru
This all comes down to how the object was scripted. The coder has not looped adjustment of the bottom nodes in plan to a change in the objects elevation...
