Aussie John
Alternate wall direction changes window position
This has been bugging me for a while.
I am finding if i create a window the position changes depending on the wall direction (ie mirror the wall perpendicular to window.
Below is a script which mimics the structure of a composite wall. Placing it in a wall and making a mirror copy of the wall gives the result in the attached file.
I also find that if the wall is mirrored then the skin numbers work from the opposite side of the wall which is rather annoying.
Can anyone give me some hints here? thanks
!2D Script
row=1
add2 -a/2,0
for i=1 to wall_skins_number
skinF=wall_skins_params [row][1] !!skin fill
skinT=wall_skins_params [row][2] !!skin thickness
FILL skinF
poly2_ 5,3,
0,0,1,
a,0,0,
a,-skinT,1,
0,-skinT,0,
0,0,1
add2 0,-skinT
row=row+1
next i
del wall_skin_number
del 1
Cheers John
[/size]
Hi John,
I think you have to use the "SYMB_MIRRORED "
and pay attention to
WIDO_ORIENTATION , SYMB_ROTANGLE
and other (see the Global/ general element Parameters)
ie.:
IF SYMB_MIRRORED THEN MUL2 1,-1
row=1
add2 -a/2,0
CU mirco
Aussie John
i've discovered i can use E~ too ( symbol flipped)
Cheers John
[/size]
