Drawing units and Drag & Drop code
When dropping elements on a script window to create code, if the drawing units are metric, the result is decimal meters. If the units are any form of imperial, the result is feet & decimal inches. The setting of the Working Units preference has no effect beyond the metric/imperial distinction.
Is there a way to force (persuade?) the units of the resulting code to a different format? Specifically, decimal inches. Thanks in advance,
James Murray
0 Replies 0
