Aperture Placement
Paalanen
Hello everybody,
Might there be a way to limit vertical placement of an opening to e.g. the heights of brick layers (,so as to not having to "cut" any bricks)? I.e. restricting the vertical movement of the opening to a certain "step value". It seems like AC_Sill_To_Curr_Story cannot be restricted at all.
All the best,
Paalanen
Certainly the overall height (size) of the window can be restricted to brick coursing as it is a parameter of the door/window, if you know a bit of GDL.
But I don't think the placement height can be restricted, as it is not a parameter.
Yes, the height I can restrict. Would've been good to also restrict the placement.
Thank you so much for your quick reply!!!
Kind regards,
Paalanen
