ArchiCAD 18 Master ID Label
I know this has been an issue for a while but does anyone know the gdl I could put in to the structure label 18 so that it reads the Master ID in a hotlink?
I want to use the Master ID that is in the ID Label 18 and also use the 'Oval' shape that is in Structure Label 18
Ideally I would like to use the Generic Label 18 but it does not read the Master ID either and the frame touches the first letter.
Hopefully the attached image shows the issue.
2 Replies 2
Image Attached
In ARCHICAD 19 several of the new Labels (e.g "Identification Label 19") do use the Master ID (they can display the Compact ID - ID without the Master ID prefix - , Master ID or Full ID (content of Master ID + Compact ID).
You may check their scripts to see how they do it.
There is also a post about this:
http://archicad-talk.graphisoft.com/viewtopic.php?p=235152#235152
He says you need at least AC18 build 4020 for it to work.
