2019-06-11
11:22 AM
2023-05-24
10:42 AM
Rubia Torres
Solved! Go to Solution.
2019-06-11 02:25 PM
2019-06-11 01:42 PM
2019-06-11 02:25 PM
2019-06-12 03:27 AM
Alessandro wrote:If you have migrated to the 22 objects then you should see this, where you can control frame and leaf materials independently or uniformly.
Hi, I have a problem.... I open a file Archicad 18 with Archicad 22. In Archicad 18 I used a single material for all the elements of the door. Now, in Archicad 22 I am not able to set different materials.... The door not change the single material of Archicad 18
2019-06-12 03:01 PM
2019-06-12 03:07 PM
David wrote:
Alessandro:
Check the Model pane in the Window Settings, it may be set to Override Surfaces. If the Model pane is not visible, go to Work Environment > Tool Schemes > Tool Settings Dialog Boxes > Window Tool and make the Model pane visible, it may be hidden in the default WE.
David
2019-06-12 03:07 PM
