Archicad 24 USA?
I have a stick licence for Archicad, renewed for 24. I am based in Europe and I use the Archicad INT version. However lately I've been doing drafting work for a US based firm.
Is there any way I can access Archicad 24 USA libraries?
Or is it available for Europe based users?
On the Graphisoft website there is only the INT version available for Archicad 24. Or am I missing something?
I'm asking this because I noticed a few differences between the INT and USA versions (the US contains a few useful National CAD Standards) and by looking at it, the USA version would save me quite some time creating my template.
Thanks!
2 Replies 2
The libraries are not available as a separate download; you'd have to download the USA version and copy the libraries from there.
https://graphisoft.com/resources-and-support/downloads?localization=USA&type=AC&version=24
If you don't see USA as an option, you would probably have to use a VPN that makes it appear that you are in the US.
vistasp
I wish it wasn't this way. While I fully understand that additional library parts are developed within different regions, and those regional offices sometimes want to restrict access to them, with increasing numbers of people working across borders, it might be time to have a global library with the best parts from all regions. Need to watch out for bloat, though.
If certain objects are developed exclusively for customers (paying extra) within that region then, by all means, put them behind a paywall, but I don't think it's good to deter the usage of standard libraries.
I think such an attempt was made (was it the ACE library?) a few years ago, but it didn't go very far. The time and resources required to maintain it must have been overwhelming. If I remember right, it also contained some objects that were proprietary, but that's a separate story.
Sorry about hijacking this thread.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
