RobiLMan
Archicad railing tool – can’t move horizontal rail along the ramp direction
Hi, Im trying to move the middle horizontail rail along the ramp direction but it seems like it is locked at 1000 mm distance even with distance set to 2000. Language of Archicad is czech
Operating system used: Mac Apple Silicon Tahoe 26,1
1 Solution
Guru
That would be the Inner Post. Check your Segment Settings.
Distance from Previous only does anything if you set the pattern to Fixed Length.
Ling.
Go to post
1 Reply 1
Guru
Ling.
