Cosminn
Array parameters
Hi all, my name is Daniel and i'm from Romania. I started creating more GDL objects, and i got a problem with array parameters, maybe you can help me. I have 3 parameters A, B and C. IF A=2; B=3 then I want that parameter C have 2 values because A=2 and another 3 values because B=3. So I want 5 values for parameter C. I hope you will understand, i'm sorry for my english.
Sincerely,
Daniel
Dave Seabury
Daniel,
A description of what you are trying to construct would help.
If you have an array (array_C) with the following values
ARRAY_C
10
20
30
40
50
and lets say A=2, B=3 If you want to pull values from the array_c
FOR n=1 to A+B
array_c
do something.............
next n
This would pull a value of "10" for the first instance of array_c[1]
and a value of "20" for the second instance of array_c[2]
etc, etc
Again, not sure what you are trying to do though.
David
AC 19-26 Windows 10 64 bit, Dell Prercision 7820, Xeon Silver 2414R ( 12 Cores), 64 GB Ram, Quadro RTX 4000 8GB
