Does anyone have or know where I could get a window and door maker thatās works properly for Australian windows and doors. This issue is driving me up the wall.
Australian standard for window numbers are height x width then the description of the window.
Examples.
Sliding window thatās 1570 high x 1210 wide is commonly marked on plan as 15-12SW
Double hung window that is 1810 high x 610 wide is marked 18-06DH
Australian essentials library does this to a degree⦠problem being if you have a height or width over 50% of a round figure it rounds up 2.. what the...?
Meaning if I have a height or width of 1200 up to 1249, happy days, as it will mark it with a ā12ā⦠if I the height or width is 1250 up to 1299 it marks it with a 14⦠so if I have a 1260 x 1580 window I get a door marker of ā14-17ā when it should be 12-15⦠this is useless.. and even if it did work iv been told its getting removed in the essentials 12 libraryā¦
Then the ādimention markerā labels it a width x height with no description.. which it wrong and useless. Iv found a marker that will label height by width but no descriptionā¦
So please, anyone know how to make this work without having to put manual text next to each window and door I insert
same with double doors.. if u have 2x820 doors, it marks it as ā1640ā instead of 2x820āsā¦
I donāt want to use ID markers and a schedule as it is a head ache for people who are looking at the plans.
I hope all that makes sense?
GeNOS
