Does anyone have or know where I could get a window and door maker that’s works properly for Australian windows and doors. This issue is driving me up the wall.
Australian standard for window numbers are height x width then the description of the window.
Examples.
Sliding window that’s 1570 high x 1210 wide is commonly marked on plan as 15-12SW
Double hung window that is 1810 high x 610 wide is marked 18-06DH
Australian essentials library does this to a degree… problem being if you have a height or width over 50% of a round figure it rounds up 2.. what the...?
Meaning if I have a height or width of 1200 up to 1249, happy days, as it will mark it with a “12”… if I the height or width is 1250 up to 1299 it marks it with a 14… so if I have a 1260 x 1580 window I get a door marker of “14-17” when it should be 12-15… this is useless.. and even if it did work iv been told its getting removed in the essentials 12 library…
Then the “dimention marker” labels it a width x height with no description.. which it wrong and useless. Iv found a marker that will label height by width but no description…
So please, anyone know how to make this work without having to put manual text next to each window and door I insert
same with double doors.. if u have 2x820 doors, it marks it as “1640” instead of 2x820’s…
I don’t want to use ID markers and a schedule as it is a head ache for people who are looking at the plans.
I hope all that makes sense?
GeNOS
