ā2017-01-01 01:29 AM
ā2017-01-01 03:59 PM
ā2017-01-01 11:39 PM
ā2017-01-02 03:19 PM
ā2017-01-02 04:11 PM
ā2017-01-03 12:54 PM
vfrontiers wrote:Hi very nice object.
You're a genius!
Best practice or not... it worked...
And it reinforces my suspicion that the GS parts can get so over inflated with code...
Honestly... those 10 lines of codes (and 5 lines were to create hotspots) does the same thing as their 4 pages of code...
ā2017-01-03 02:58 PM
ispyridis wrote:There is a command Rebuild & Regenerate that will run the script to get the Object to rotate to the Camera.
Is there a way to update rotation to the camera automatically just before rendering? or we just have to select all objects and open settings dialog to update?
ā2017-01-03 04:03 PM
ispyridis wrote:So ONE time... out of the many renders I've been doing over the past couple of months, I did notice the plants shift just before the render engine engaged..
ā2017-01-04 05:45 PM
vfrontiers wrote:Wow! That's almost as useful as your code! Would never have thought to look there. A double thank you, Duane.
ALSO... I used to laugh at PINTREST but upon joining, I have found a TON of fresh CUTOUT TREES and SHRUBS to include in my library.
