ā2016-03-04 03:02 AM
ā2016-03-04 03:14 AM
if PARAMETER_1 then !!!do nothing else LOCK "PARAMETER_2" HIDEPARAMETER "PARAMETER_2" endifSo if your Boolean parameter is ON the other parameter will be available but if it is OFF the other parameter will be locked and/or hidden.
ā2016-03-04 03:36 AM
ā2016-03-04 06:08 AM
4thorns wrote:No you can't make the cursor jump to any particular field.
Edit. Another way to put it. If I put a check in the first parameter the the cursor automatically jumps to the input field of the second parameter.
ā2016-03-09 01:21 AM
