Autotext code for Back Reference?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2012-05-17 03:39 PM
Attempting to reverse engineer the standard built-in Graphisoft title handling method of back referencing is causing me considerable discomfort.
What do people normally do? when scripting for back referencing?
ArchiCAD 8-29 | Twinmotion 2025
Windoze 11 PC | Intel Core Ultra 9 285K | Nvidia Gforce RTX 5090 | 64 GB | 2x4K monitor extended desktop
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-04-25 11:14 PM
I'm looking into a similar issue.
Shoegnome Architects
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-04-29 01:33 AM
I started by taking one of the standard Archicad titles which has the back referencing function working and stripped out everything that didn't apply to it, leaving just the code and parameters for the back referencing. Then it was just a matter of building it back up to appear the way we wanted it. Hope this helps.
Started on AC9 | Currently AC27 & AC28 | BIMCloud | GDL
Mac Studio (14,13) M2 Max, 64GB, 1TB SSD | MacOS 15.5
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-04-29 05:57 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-05-09 04:49 AM
I use the built in reference marker as can be seen in screenshot
but when i go to back reference there is no selections available??
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-05-09 04:09 PM
It looks like the problem you're running into is that you're trying to backlink back to a linked marker and not a source marker. Backlinks unfortunately only direct back to source markers.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-05-09 10:53 PM
After reading it convinces me more that I should be able to back reference the detail, but I cant because as with the image above
When I right click on a detail drawing in a layout and under the title tab section, click the back reference button, It says "Note; The Back reference function is only available if this drawings source has a source marker"
But as far as im aware it does have a source marker because when i go to the reference marker on my cross section and right click on the reference marker and tell it to "Open Detail Drawing" it takes me back to that detail drawing (so that is linked correctly)
Also when I select the reference marker as a source marker
'with Marker Reference to" and browse to define the marker reference
to the particular detail on the particular page.
Then I go back to the detail placed on the layout page
"Back Reference" button
Enable back reference tickbox is available
and then Select All Availbe tickbox becomes available
there is still nothing below to select from?
obviously i have done something wrong?
I can link details to their source layouts
but not back reference them to the reference markers layouts?
Also With the reference marker set as a source marker
I have also gone through and picked all 4 of the 'with Marker Reference to'
options: Viewpoint, The Selected Drawing, The first placed drawing of the viewpoint & The first placed drawing of the selcted view
Picked independantly then gone back to the detail on the page layout to try and back reference, but there are no options to pick from once Enable Back Reference has been selected
Ive figured out that it is to do with the marker I am using
the one which displays how I want it to does not allow back referencing
however the others allow it without the appearance I am after
maybe i need to make a custom detail
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-05-09 11:05 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-05-09 11:25 PM
and I have my Independant Details , but I can set them to Source markers instead of linked markers.
It kind of sucks that i cant just tell the marker where I want to set the source
well i kind of can but archicad doesnt understand it
Our drawing template already has independant details set up
I guess i will have to change how I create detail drawings on the next job
because its getting to late to be messing around creating new detail layouts again and having to re reference them.
Because this job needs to go out shortly.
I might play around with what you are talking about with one detail to get the hang of it.
Although im not sure what settings i should have on the marker to get it working how i would like???
Do i create a new detail viewpoint, or create a linked marker?
And where should the marker reference to?
also is there a way i can do this in no particular order?
without the detail numbering consecutively?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2013-05-09 11:53 PM
Used the detail tool marker to create a new detail viewpoint on my cross section
this generates a bunch of lines automatically in the detail view
I then place this new drawing on a page layout
add a title that allows back referencing and try to back reference it
still doesnt let me do it! nothing to select from?
