Display malfunction of Graphisoft ID dashboard
Learn more
Beam complex structure variable
Hi.
I'm trying to automate labeling a steel structure made of different IPE, HEB and HEA profiles. I've imported those profiles using "Import Standard steel Profile" function in Archicad and used them to build up my structure made of beams and columns elements. Now I would like to use "Label Elements" and a custom made "Label Everything" label downloaded from the depository: http://archicad-talk.graphisoft.com/object_depository_browse.php?browse=Depository/01%20General/Cust...#
So to get it working I need the name of the variable of the complex structure name...
I really can't find it anywhere...
I tried "gs_complex_structure" and similar but it didn't work.
Thanks for help
4 Replies 4
Ben Cohen
Hi
Try using 'ac_beam_profile_name'. This needs to be a text type parameter that you create in the label parameters.
Here is a link to how these parameters work and the full list of available parameters
http://www.graphisoft.com/ftp/techsupport/documentation/developer_docs/BasicLibraryDoc/14/LibDevGuid...
Ben Cohen
Mac and PC
Archicad (Latest Version) aus
www.4DLibrary.com.au
It doesn't work.
What I do is in the "Label Everything" label I choose :
Method: Select element
Choose element type: Object
Line 1: ANY parameter
Any parameter from object: ac_beam_profile_name
This plots no result.
If I choose in the label the "Choose element type : BEAM" I have the list of available beam parameters but there is no such thing as "beam profile name" or similar.
It must be possible to do such a thing as in the schedules I can plot this parameter without any problem as it is available in the standard parameters of the beam as a "Cut Fill Type / Composite / Profile "...
Maybe using the "Label Everything " label is not a good idea ... any sugestions on how to make such a label ?
I've made a workaround using the ID and standard "ID Label" but I feel this is not the way it should be done. What I would like to get is more less this:
Brad Elliott
Did anyone ever figure out how to do this? There is to much opportunity for error when you have to manually set the ID.
Mac OS12.6 AC26 USA Silicon
M1 Macbook Pro
