Beam label - Displaying profile name.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
2010-07-08 02:17 AM
2010-07-08
02:17 AM
In a schedule you can use the 'cut fill type' parameter to display the profile name, so would using the BEAM_FILL parameter somewhere within a label do the same? I also see on this page that 'ac_beam_profile_name' returns the profile name. How do I use either of them?
For example
pn= REQUEST ("ac_beam_profile_name","", beampro)
comes up with an error.
Many thanks.
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-08 06:15 AM
2010-07-08
06:15 AM
Hi Peter
Try creating a 'Text' type parameter called 'ac_beam_profile_name'. Then use this in your scripts.
HTH
HTH
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2010-07-08 05:30 PM
2010-07-08
05:30 PM
Hi Ben,
Thanks for that, it works perfectly!
It's simple when you know how!
Cheers.
Cheers.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-05-23 05:37 PM
2011-05-23
05:37 PM
I Can't do that... please could you explain better the way to do that? I tried to create a string variable called "ac_beam_profile_name", but in this way the string is empty (or is the same of what you write it). I tried other way to do that but without results...
Any help is much appreciate!
Peter wrote:
Hi Ben,
It's simple when you know how!![]()
Cheers.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-05-23 09:47 PM
2011-05-23
09:47 PM
You're half way there!
Now you have created the variable "ac_beam_profile_name" in your beam label, simply refer to that variable in the script where you would like the beam profile name to appear.
In the image attached, you can see I created a boolean variable named "prof_on" to determine whether "profdisp" either equals the profile name or nothing. It's probably a bit crude, but it seems to work!
Hope that helps!
Hope that helps!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-06-09 05:42 PM
2011-06-09
05:42 PM
Thank you for help! I had done it but not the right way, and I was going crazy... I'm developing a label unique for all kind of elements, after complete I'll post it for everybody!
In the image attached, you can see I created a boolean variable named "prof_on" to determine whether "profdisp" either equals the profile name or nothing. It's probably a bit crude, but it seems to work!![]()
Hope that helps!
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
2011-06-30 05:04 PM
2011-06-30
05:04 PM
I've done It! Anyone who needs of my label which recognises the type of element (wall, beam, column, roof, slab, windows and doors) and label the name of profile, x & y dimensions, height, volume, weight and base elevation please request directly: glongo1984@gmail.com
Of course it's a beta version, I tested many situation but something may be improved....
