Best object/library for 3D Roof Tiles
D_BRANDT
Can anyone recommend a plugin/library/object for 3D roof tiles?
Maybe a more manual solution where you can apply tiles to one face at a time.
I've been looking at Bramac and Cadimage Tools, but on roof tiles especially they lack a bit when it comes to tile types
7 REPLIES 7
Miha_M
The BimObject site probably has some.
Some manufacturer specific solutions are provided by Eptar, made in Hungary. Worth a try. https://www.eptar.hu/eptar_letoltes_addon.php?lang=en.
| Archicad 4.55 - 27
Nader Belal
Mentor
Aside from this and only if you know Grasshopper, then you should see if you can model your tiles in Grasshopper and use the direct link to import the tiles back to your ArchiCAD model
Guru
How big are your tiles? For what reason are they needing to be modelled? If it is for 3D, can you not just use a texture with a displacement map?
Ling.
Jochen Suehlo
There are different websites, that offer single modelled roof tiles to be used with the roof accessory, e.g. https://eptar.hu/eptar_letoltes_addon.php?lang=en#bramac
Which kind of tiles you are looking for?
Jochen Suehlo . AC12-28 . MAC OSX 14.4 . WIN11
D_BRANDT
Thanks guys!
I see some of the plugins is in Hungarian - what a shame the don't make a english version too 😕
What I wanted the most was a more manual solution, maybe a element you could stretch to fit each roof side, and a element for the ridge tile.
The more automatic solutions seems to have problems when roof and walls are connected.
Guru
There is a "Roof Surfacer" object in the Goodies Package. It has metal roof and tile options. Only works for single-plane roofs though, so you will have to explode any multi-plane roofs into single-plane.
Ling.
muril00ng
There's a new library here: https://youtu.be/o5l7ieAllw0
____________________________________
Murilo Noleto
http://www.kilobim.com.br/
AC 12 - 27 | Win 10 | 16GB | NVidia GTX 1050Ti | AMD Ryzen 7 1700X
