Steve Jepson
Bi-fold Hangar Door
Does anyone have a bi-fold airplane hangar door they would like to share with me? Some other object that would work at least for 3d view?
I could make it from roofs but if there is a door like this already made it would be great.
Thanks
7 Replies 7
Steve Jepson
kind of like this with two awning windows in two walls (one slanted) and an seo
Steve Jepson
it can almost be done with just two awning windows in the same place
Not quite good enough. I need a real vertical bi-fold door
Steve Jepson
best I could do was 2 awing window in the same vertical wall, one empty window, and an seo
Obviously it can be done but i have nothing ready.
Have you considered using:
- an empty door opening
- two slanded walls?
Cadimage's Window tool has a horizontal bifold option, see below. Doesn't look perfect (at the fold) but might be worth a look?
OR, what about creating a door (vertical) that is the right size and shape, convert to morph and rotate. Place it in an empty opening?
You could even save the morph back as a door object.
It won't have adjustable parameters (other than the overall size) but it will still be a door.
Steve Jepson
Good idea. Thanks. The cadimage window to morph then, save as a door is the way to go for me.
