Barry wrote:
I am building a Bill of Material database. I have created a few "super" parts, is there a way for me to script in the part to select the correct properties based on a set of parameters? (i.e.- a window ID of 3046 will choose a 3046) What is the variable that relates to the "Link Properties" in the parts? Thanks.
Barry,
I believe you want to write a custom Property script
inside
the window object (or CALL such as script from the Property script
inside
the object).
This is different than linking a stand-alone Property Object to an element based on criteria. In doing that linkage, you cannot have dynamic adjustments as you are describing AFAIK ... (without using user global variables, perhaps...although I haven't experimented with the evaluation order to see if even that would work).
HTH,
PS We're starting to have various overlapping forums in which to address these kinds of questions. The Components, Descriptors and Property Script portions of a GDL object clearly fall into this forum, but they also fall into the new Calculate forum (and, to some extent, Data Exchange). Whew.
One of the forum moderators
AC 28 USA and earlier • macOS Sonoma 14.7.1, MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
