‎2015-08-14 09:12 AM
WOPE 19.0.0 build 3003
Converting GSMs to XMLs
Converting XMLs to GSMs
C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar Post.xml(0) : warning: Macro may be unused: 3DMD Railing Vertical Bar Post.xml
C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar M.xml(0) : error: Missing ancestor with main GUID {2ED4FA1F-7BC3-429A-BBC7-EECC557C49CC}.
C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar.xml(0) : error: Missing ancestor with main GUID {2ED4FA1F-7BC3-429A-BBC7-EECC557C49CC}.
C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar.xml(39) : warning: (in Script_1D) : problem in macro call
C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar Master.xml(5395) : warning: (in Script_1D) : View dependent global 'GLOB_CONTEXT' used in parameter script
What does it mean? ‎2015-08-15 03:41 PM
mariosmic wrote:
Now GLOB_CONTEXT is Deprecated.
When I download a 16 version on Bim Components it reports me:
WOPE 19.0.0 build 3003 Converting GSMs to XMLs ----------------------- Converting XMLs to GSMs ----------------------- C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar Post.xml(0) : warning: Macro may be unused: 3DMD Railing Vertical Bar Post.xml C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar M.xml(0) : error: Missing ancestor with main GUID {2ED4FA1F-7BC3-429A-BBC7-EECC557C49CC}. C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar.xml(0) : error: Missing ancestor with main GUID {2ED4FA1F-7BC3-429A-BBC7-EECC557C49CC}. C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar.xml(39) : warning: (in Script_1D) : problem in macro call C:\Resources\directory\037dea269b8c453cb413219eaa93db00.Graphisoft.ObjectPortal.WopeRole.WC\XML5852\3DMD Railing Vertical Bar V1.01 R16\3DMD Railing Vertical Bar Master.xml(5395) : warning: (in Script_1D) : View dependent global 'GLOB_CONTEXT' used in parameter scriptWhat does it mean?
Now We can't download on BIM Compontens objects V16?
Now we can download only object v19 with GLOB_CONTEXT replaced with the new working command?
Or the problem is in the other reported "errors"?
What is the different among "warning" and "error"? What is fundamental?
Is the ancestor the subtype?
I'll continue to try to upload a new object empty with only GLOBAL_CONTEXT used.
‎2015-08-19 06:56 AM
Gergely wrote:Thank you Gergely.
I hope I could help, but it there is any more questions, feel free to contact me.
‎2015-08-19 01:09 PM
mariosmic wrote:Gergely wrote:Thank you Gergely.
Now Every error reported on the warning txt report is solved.
I'm starting to handle with XML_Converter.
But I I have still problem to upload on BIM Components.
In the last upload Graphisoft report me another email with problems.
But there isn't any txt log file attached!!
This isn't the first time it happens.
In the report of XML_converter using "finalizelibrary" with "-check 9" it reports me a huge list of the error of unused parameters.
Meanwhile I decided to postpone solve this problems due to the fact they are tens and tens of parameters;
my railing objects (http://www.3dmediadesign.it/) are very complex and I used hundreds of parameters.
Do you think the problem could be the unused parameters? Bim Components never reported me this problem.
I really appreciate your help.
Thank you
