Bug in AC11 Library Part
No matter what I do, when I use the Library Part "Jacuzzi Square" in AC11, it gives me an error saying, "There are several /8/ hotspots with same unique ID in the library part: Jacuzzi Square".
3 Replies 3
In the future, please make the title of your post the library part with which you are having a problem. There are dozens (hundreds?) of bugs in the library parts..so 'bug in ac11 library part' is not too informative. 😉
When I select and place the default part, there are no error messages. Are you sure you have the current library? (Help > Check for Updates..._
AC 29 USA and earlier   •   hardware key   •   macOS Tahoe 26.5.2 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
I couldn't reproduce the problem either. The hotspots are created by a macro called "Resize_A_B_ZZYZX.gsm". Perhaps you have a problem with this part. Are you working with a current (unmodified) AC11 library?
__archiben
i can't reproduce either - no matter what combinations of settings i make.
can you post your settings?
~/archiben
b e n _ f r o s t
