2006-07-06 08:02 AM
2006-07-06 08:29 AM
2006-07-06 11:45 AM
2006-07-06 12:12 PM
!-----SET SIZES----- len=1.0 dep=1.0 wall_thk=0.090 !-----SET POINTS----- x1=0.2 : y1=0.0 : z1=0.3 x2=1.0 : y2=0.5 : z2=0.6 x3=0.0 : y3=1.0 : z3=0.3 !-----CALCULATE VALUES FOR PLANAR EQUATION----- co_a=(y1*(z2-z3))+(y2*(z3-z1))+(y3*(z1-z2)) co_b=(z1*(x2-x3))+(z2*(x3-x1))+(z3*(x1-x2)) co_c=(x1*(y2-y3))+(x2*(y3-y1))+(x3*(y1-y2)) co_d=-((x1*((y2*z3)-(y3*z2)))+(x2*((y3*z1)-(y1*z3)))+(x3*((y1*z2)-(y2*z1)))) !-----CALCULATE POINTS FOR CUTPLANE----- IF co_a#0.0 THEN x_cut=-co_d/co_a ELSE x_cut=0 ENDIF IF co_b#0.0 THEN y_cut=-co_d/co_b ELSE y_cut=0 ENDIF IF co_c#0.0 THEN z_cut=-co_d/co_c ELSE z_cut=0 ENDIF !-----DRAW OBJECT WITH CUTPLANE----- if x_cut and y_cut and z_cut THEN CUTPLANE x_cut, y_cut, z_cut, 0 PRISM_ 9, 5.0, 0.0, 0.0, 15, len, 0.0, 15, len, dep, 15, 0.0, dep, 15, 0.0, dep-wall_thk, 15, len-wall_thk, dep-wall_thk, 15, len-wall_thk, wall_thk, 15, 0.0, wall_thk, 15, 0.0, 0.0, -1 if x_cut and y_cut and z_cut THEN CUTEND !-----DRAW SPANING PLANE----- MATERIAL "Glas" PLANE 3, x1,y1,z1, x2,y2,z2, x3,y3,z3 !-----RECALCULATE POINTS IN PLANE----- PRINT "If all Points are on the Plane, represented by the equation, all following results sould be zero." PRINT "POINT 1: ",co_a*x1+co_b*y1+co_c*z1+co_d PRINT "POINT 2: ",co_a*x2+co_b*y2+co_c*z2+co_d PRINT "POINT 3: ",co_a*x3+co_b*y3+co_c*z3+co_d PRINT "The constants a/b/c/d: ",co_a,"/",co_b,"/",co_c,"/",co_d END
2006-07-06 12:17 PM
2006-07-06 12:37 PM
