‎2006-09-29 03:44 AM
‎2006-10-02 11:45 PM
‎2006-10-03 12:14 PM
laszlonagy wrote:Yes this makes sense but I would assume that when comparing the server and local cached libraries AC would understand that in order to update a changed object in the cached PLA/LCF it would need to replace the entire PLA/LCF file? If not then i guess library caching would not work with library containers.
I think LCF files and PLA files work similarly.
I know that Library Objects located within PLA files cannot be updated. You have to extract the PLA file into a folder, change the extracted Library Object, and then again save the PLA
‎2006-10-03 06:48 PM
